Thanks.Hey guys i finally got an engineer to upgrade firmware. DM me for the link
What are the improvements you noticed?
Hi, can I ask for the link?Hey guys i finally got an engineer to upgrade firmware. DM me for the link
Thx, Bulgaria vpn showed an update. Its in progress...If there are no updates, try vpn. Countries: Israel, Bulgaria, Russia. Current version: QTG3.200305.006.5135.
Let's know if there's any benefit seen from getting the update. Else current India firmware seems to be working fine so far.Thx, Bulgaria vpn showed an update. Its in progress...![]()
I'm not seeing any improvements so far. However I just had a look briefly. Wonder if it ever gets Google TVLet's know if there's any benefit seen from getting the update. Else current India firmware seems to be working fine so far.
Did you upgrade?Thanks.
True, seems less stable. I got network issues yesterday and today cant get sound over hdmi workingHi, I see a lot of new bugs such as stutter and delay in playing netflix videos, random shutdown etc. Would not recommend the update
I’m on v2148 (March 21 security patch). The only issue I face is ARC keeps breaking on its own. I have to change source in the avr and/or enable disable arc to get it to work again. Also security patch is very old.v2148 changelog - v3270 changelog - not provided -
i would recommend a fire stick 4K max or a shield (tube or pro) or APTV with this TV to anyone that can afford it. The TVs internal app and UI performance isn’t very bad but it’s isnt great either. It often hangs and video stutters on seek in plex.Just a quick one… can we use this as a dumb tv? I have fire stick and shield pro.. so never need the smart features. This might make an affordable big screen option to me.
The point is can we disable all smart features and use it like a basic TV. It might turn out to be faster to use.i would recommend a fire stick 4K max or a shield (tube or pro) or APTV with this TV to anyone that can afford it. The TVs internal app and UI performance isn’t very bad but it’s isnt great either. It often hangs and video stutters on seek in plex.
Yes - of course. The TV will work well as a dumb screen!The point is can we disable all smart features and use it like a basic TV. It might turn out to be faster to use.
Great also post about bugs as there were a lot of issues on previous updates. Don't know why they don't push any update it's almost 1.5 years now.Was on Bulgarian VPN overnight and new update came in! Will post details soon (kid just having his cartoons). Most important, it gets a new interface now, looks like Google TV!
Well, bit odd, but seems that its just an interface update and software is still at the same version. Whats more annoying is that when I switched off the VPN the interface is old again. When I connect back to Bulgarian VPN - new interface suddenly...Was on Bulgarian VPN overnight and new update came in! Will post details soon (kid just having his cartoons). Most important, it gets a new interface now, looks like Google TV!
