heatednemz
Hi Members,
So as the title suggests, I'm in the market for a good atmos (5.1.2) setup that fits my budget. (Audio Only)
I move into a new home in about 6 months and I can finally have a home cinema setup that I have always wanted and this will be my first home theater setup.
I want to preface the post by saying that I haven’t yet auditioned anything and everything I write below is based on ‘internet research’. I'm no audiophile by any stretch of imagination and I am not chasing the perfect sound stage, but I do enjoy good movie immersion with boombastic bass, and that's the motivation for this purchase.
The Requirement :
The Room
My TV room is about 13 feet by 9 feet with a 10 feet ceiling. I have also attached an image to understand the layout.
The longer walls have a window and a door so I have 9 feet for viewing and seating.
So the diagram and its content are not to scale, but I want to bring attention to the surround speakers. If I mount them on the back wall instead of the side wall, they might protrude past my head. Instead I plan to mount them on the side walls facing the sofa. Is this okay?
The Front LR speakers and the Center speaker will be mounted at ear level, Center speaker will come under the TV (As of posting this, it will be a 65 inch Bravia 3 2024 model)
The red semi transparent dots are height/Ceiling speakers. I have to move them overhead the sofa instead of the midpoint between the tv and the viewer because of the fan and cassette AC obstruction. This is not ideal but its what I got to work with.
The Budget
Front (LR) - 30K
(C)enter - 25K
(S)urround LR - 20K
(W)oofer - 40K
AVR - 45K
Ceiling - 15K
This goes slightly above my budget and i would like to dial it back to 1.5 instead of 1.75 lakhs. 1.75L is the hard limit on what i'm willing to spend.
I've mostly decided on the Height speakers to be the JBL 6IC and the AVR to be the Denon S760H.
The Short List
So it comes down to the 5.1 then, here my options and thoughts :
LR = Front Left, right , C = Center, SLR = Surround Speakers, W = Woofer
C = Q Acoustics 3090Ci
S = Sonodyne Sonus 3540
W = Taga Harmony TSW 212SE
This is an assembled system that just about fits the budget.
+ I love how the Q Acoustics look
- Slightly over budget
- Sound signature won’t match across the surrounds
C = JBL Stage 135C
S = JBL A120
W = JBL A100P
+ Consistent signature across speakers
- Boxy look as compared to Q acoustics
3. ELAC Cinema 12 Package
+ Consistent sound signature
- Not much information online
- Boxy
The Confusion:
The Advice I’m looking for:
Like I said, I am a novice and this is the first step. I want to narrow down on the selection to at least 3 before I start auditions.
I am open to more models and combinations that fit in this budget.
Looking for critique, recommendations and advice from owners or people who have had experience on these models. T.
Thank you for reading the long post and all recommendations in advance.
The Requirement :
- I want immersive audio for about 85% watching movies and 15% music. All of my content will be consumed on OTT with the occasional movie running on my Plex server.
- I want enough bass to be felt in the bones but it also has to be balanced and not overpowering everything else.
- Woofer has to be concealed into a custom built TV unit (Non negotiable by wife) but will have a mesh door
- All speakers will be wall mounted, none of them will be placed on a surface.
- I don't have the space for floor standing speakers, so it will have to be bookshelves.
- Sofa is flushed to the fall, so ideally non bulky surrounds speakers.
- Rear speakers have to be a little more subtle/smaller if possible, even if it means compromising on sound a little bit.
- Aesthetics are important to me, boxy looking speaks are not ideal, but its a compromise i’m willing to make.
The Room
The Budget
Front (LR) - 30K
(C)enter - 25K
(S)urround LR - 20K
(W)oofer - 40K
AVR - 45K
Ceiling - 15K
The Short List
- Assembled
- JBL
C = JBL Stage 135C
S = JBL A120
W = JBL A100P
- Boxy
The Confusion:
- People say you can always turn down the bass on the 12 inch sub instead of getting a 10 inch. My room is small so I'm wondering if a 12 inch is overkill?
- My Woofer will be inside a tv cabinet, which will be closed with a mesh door. Does port location matter? What are my options?
- Do the surround speakers matter that much? Not asking whether I should have them but whether it’s necessary to match the sound signature?
