baijuxavior
After getting inspiration from the HTPC threads of sam9 and others, I decided to assemble an HTPC myself. I sold my himedia 600b player and bought the components for HTPC. Here I will try to discuss how I assembled the HTPC with necessary images. This was my first complete PC assembling. So I thought of sharing my experiments with fellow forum members who are interested in assembling HTPC. I have tried to include all the necessary images so that even a noob can assemble the HTPC without any hassle. For taking the pictures I had to disassemble the HTPC completely. Please excuse for the low photo quality. I had to reduce the size considerably so that I can upload the images using my GPRS connection
Hardware Used
1. Motherboard+CPU - Gigabyte GA-350N-USB3 AMD Fusion - Rs. 7050/-
2. Memory - Corsair 4GB DDR3 - Rs. 1190/-
3. HDD - 1TB WD Green - Rs.2800/- (Now the price is around 6K)
4. Cabinet - Cooler Master Elite 100 - Rs. 3400/-
5. Remote Control - Rs.600/-
6. Keyboard and Mouse - Used my old ones. The mobo has one ps2 port to connect either a mouse or keyboard.
7. Screwdriver (Star) - The only tool you need to assemble the complete HTPC.
Total cost of HTPC is appx. 12K excluding HDD, Display and OS.
I bought the mobo and memory from theitbazaar.com. The motherboard package should contain driver dvd, manuals, two sata cables of which one is L shaped and the back panel IO shield.
The cabinet was bought from ebay. The price was appx. 3.8K when I ordered it. Now it is 3.4K only including shipping. Use any 10% coupon to get discount. The cabinet should contain power cable and other accessories like different types of screws, SATA cable for slim optical drive etc. These items were missing from my package. I contacted the seller smcinternational (ebay seller ehardwarestation) and they sent all the missing components quickly. Their service was excellent. Their CC called me atleast five times and assured me the prompt delivery of the components.
Top View:
Back view:
The inside story:
The remote control is a generic one which emulates keyboard presses. You can use it with xbmc out of the box. However functions of some keys like email, www, close button etc. cannot be changed without third party apps. You can use 'Eventghost' to configure the remote and control xbmc. I will discuss it later. For greater usability buy a RC6 remote control like those used with HP media center PCs. 'srinisundar' has ordered one for me and will probably reach me by next week.
Assembling
You will need to completely disassemble the cabinet in the following order to fix the mobo, hdd etc.
Remove the front bezel: It has three plastic clips at the bottom and two on top. First press the three bottom clips to loose the bottom of the bezel, then remove the bezel from the top.
Front bezel removed:
Remove the top HDD bay. It is fixed by three screws - two on either side and one on the front concealed by the bezel. Remove the power supply also.
Fix the IO shield at the back:
Fix motherboard:
Fix front USB, audio and L shaped SATA cables:
For audio cable, I used the HD audio cable marked as azalia. You can use AC97 also.
Connect the SATA and power cables to the HDD and mount the HDD at the bottom of the bay:
Connect front panel cables for HDD, PWR LEDs and Power button. Refer to the mobo manual for pin configuration:
Connect the power cables:
Neatly route the SATA, USB and audio cables:
Fix the hdd bay, PSU and memory:
Finished views:
OS and XBMC
I used Windows 7 ultimate as the OS. You can use Home Premium also. XP can also be used, but Win7 is recommended. Linux users can install Openelec for Fusion APU.For Win7, I set aside a generous 50GB partition out of the 1TB HDD. I partitioned the rest into two - for songs (200GB) and movies.
Since this HTPC doesn't have a DVD drive, I used a USB pen drive for the installation. I had stored the OS as a ISO image in my laptop. Using UltraISO 'burned' the DVD image to the USB drive. You should select the boot device as HDD instead of USB if you do so. Copying the contents of the OS DVD to the USB drive and boot from USB will also work.
You can refer to sam9s thread to know more about XBMC.
I will discuss how to configure the remote control and control XBMC using eventghost later.
Hardware Used
Top View:
Back view:
The inside story:
Assembling
Fix motherboard:
Finished views:
OS and XBMC
