All - I have used my PJ now for more than 40 hours.. and I have some issues that I have noted down below.
- There is a running wrinkle horizontally across the screen (I am not sure how to best describe it, more like a running line which distorts the image - you will notice it when you try to find it) when I attach my PJ to my ASUS laptop i7, 2nd Gen processor). But when I connect it to my PS3 it works fine and there is no such issue.
Couple of reasons could be -
- My apartment has got a bit if power/voltage issues so might be low voltage issues.
- My laptop or VLC/POT Player is not able to handle MKV files. This can also be an issue
3D Issue -
When I try to watch SBS 3D videos (via the laptop) the PJ does not automatically change it and I am doing it manually by selecting the right option and once I change the option. The signal disconnects from the laptop and then there is no signal to the projector again maybe my laptop is not able to manage this kind of content or maybe VLC player/POT player issues ? I get no Video Output and the only option is to disconnect the HDMI cable and change it again for 2D output...
But the moment I try playing it from my PS3 - all superb
Can some fellow FMs pls post their thoughts ?
