Finyl Vinyl
Well Done Steve and thanks for sharing the W.I.P pics. When can I hear the 301 sing?
Likewise!!!
Hi Anilva,
Thanksif you mean thin wire to thick in the signal cable then no it's all thin tonearm wire only right to the plugs. I think the black sheathing where the thin wires end makes it look thick. Is that what you're referring to? The ground wire I will be soldering to a thicker wire so there will be one joint but considering it's ground wire am guessing it won't matter.
Santhosh,
When you're back you can! Or maybe Jan we'll do a session first week or so. Work's a little crazy right now so just enjoying the project itself. That om 5e is still amazing me record after record!
Hey jls001, there's one on eBay right now, link below:
SME genuine HEADSHELL MOUNTING COLLAR | eBay
A bit pricey, but a new piece from SME might well cost more.
Hi Joshua,
There's a small screw underneath the tonearm at the beginning of the armtube where it meets the nut. After removing this, its a press fit. You can't do one individual pin. If its gone, its gone, you'll need a new nut with the four pins.
All the best!
Where have you been? Hibernating for so long?
