parambir
Hello
I received my Minix Neo U1 today from USA along with A2 Lite and could not wait to open and plug it in... This is my first streamer.
The 7.1 setup - Yamaha RX V-671, Sanen Towers (put up for sale), PA CS10 centre, Sony Sub, PA OWM 3 surround and PA RM8 rear. Borrowed a 32" LED from a friend. (My wife would have killed me if I removed the one from bedroom for my trials !!!
I plugged in the device and booted it up. I connected the Ethernet cable from my WiFi modem. Yes, I did not connect it on wifi to the modem. Why? I will explain that.
First thing to do is check for updates... Mine was Dec 15 vintage and it took three more updates till Apr 16 before I got it running.
Now this being my first streamer, I took my time to get the hang of it. It was a breeze getting it going. First I tested was playing Youtube content. No problem. Enjoyed HD or 720p videos.
Next I plugged my USB hdd with HD movies DTS 5.1. Started playing the movies. This was the first time I was playing 5.1 content on my home theatre since I did not have a 5.1 player before I got this streamer.
I must say... I purely loved it. Watched Fast and Furious 7 again on the home theatre and the sound was amazing. Played through XBMC which came bundled.
I also loaded couple of apps from the play store. Air mouse requires some getting used to, but not that tough. I did not unpack the stock remote at all.
Now the part, why not on Wifi... well I wanted to use the 5 dBi antenna of Minix as a wifi hotspot. So in a sense it acted like a repeater for my wifi which is in one part of house and I do not get good strength in living room.
On the bluetooth I connected my mobile though I did not find much use of it.
Here I have a question too for others who have been using streamers... Up untill now I used to play my songs through the BT from my mobile to a BT receiver connected to Audio port of Receiver. Can I use Minix to play my songs from my mobile or I connect mobile on BT to minix and with some app play songs which are further played through Minix. I mean I would like to do away with this BT receiver.
I know the experimentation has just begun. Shall keep you all posted as and when I make some progress.
Thanks for reading. Cheers...
