Hi.. I bought AT LP60 from Canada and using a converter (cheap) from India for voltage. The TT is connected to a Sonodyne PCube speaker. In Phono mode there is a faint sound however in Line mode there is no sound at all from the speaker... i contacted Sonodyne they said could be issue with the converter as the speaker should work as it is working with our normal other dvd players easily...
AT service folks from India said they need to see it physically because as per photos everything was looking ok...
So do you think the voltage converter can be an issue here? that too causing no sound at all in Line?
What else can be issue.?
Also what kind of phono speaker can I use if there is no Line issue resolution for now?
Thanks in advance
Thanks in advance
