thanks ..it is a combined effort i am just a trigger you can say ...
but i strongly disagree use of carbon film resistor(5% is way too bad as the audio output depends on the thermal stability of the resistors ) and locally available cheap parts.
if any one wants to go cheap ,ebay china seller sells 10$ (1% tolerance,all values)packs for resistors and capacitor kits.. one pack each will be enough for 3 or 5 dacs...
but i have serious doubt on the result.
mouser parts exactly match designer recommended ones..
if tally3tally gets vishay dale resistors of same parameters
we can use .but capacitors should not be replaced except they are wima or such audio grade ones.
switches as per the owners choice.. after all cabinets will be designed here so no fitting issues will come
let the wolfson DAC chip give the best for that design..
@tally3tally
check SAINI ELECTRONICS too.. they have branches in all metros...
but i doubt much you will get ..wima are possible i have seen some in bangalore.
soldering you need a fine point one ,static safe.static safe tweezers..
cheaper ones are gold point(Rs400)/soldron smd(Rs650).. you need pretty good practice too
magnifier with light needed.
remember i
if precautions not taken static damage will NOT fully damage the chip but will make it
last less .. or degrade sound output
