soumyajit92
Hi guys, looking for some kind of ip rated moisture/waterproof tv for my master bathroom. Has to be at least 32inches or bigger. Not getting any useful results from google in india. Any leads ll be helpful. Thank you.
Your requirement is quite unique, i doubt you would buy this, but such a product is actually availableHi guys, looking for some kind of ip rated moisture/waterproof tv for my master bathroom. Has to be at least 32inches or bigger. Not getting any useful results from google in india. Any leads ll be helpful. Thank you.
Agree, but i guess the humidity will play a major role in reducing the equipment life.I would do desi jugad though, put some waterproof transparent cover on tv, and tape the open ends so no water goes in.
I doubt this is available in India..Your requirement is quite unique, i doubt you would buy this, but such a product is actually available
55-Inch Class Outdoor QLED Smart TV | The Terrace Partial Sun | Samsung US
Shop the 55-Inch Class The Terrace Partial Sun QLED 4K Outdoor Television. Find the perfect big screen TV for your outdoor entertainment.www.samsung.com
If someone is that rich to put a tv in the bathroom, might as well put a budget AC in there to live The Crib lifeAgree, but i guess the humidity will play a major role in reducing the equipment life.
A/C in the bathroom is a horrible idea no matter how rich you are. Also, it won't help with humidity due to the steam if you're using a hot shower.If someone is that rich to put a tv in the bathroom, might as well put a budget AC in there to live The Crib life
Steam will kill it if anything else can't.. SAMSUNG Terrace when it launches.
Even if you ignore the richness barbs here, must think how long you spend in your bathroom to justify a tv setup. If it's not a lot, do look for a smaller setup based on raspberry pi or arduino with monitor enclosed behind a mirror for basics.
Check in Indiamart website if there are commercial TVs that can handle humidity and water splashes.Hi guys, looking for some kind of ip rated moisture/waterproof tv for my master bathroom. Has to be at least 32inches or bigger. Not getting any useful results from google in india. Any leads ll be helpful. Thank you.
Have centralised ac.A/C in the bathroom is a horrible idea no matter how rich you are. Also, it won't help with humidity due to the steam if you're using a hot shower.
For now installing a regular cheap tv. We ll update later if i mange to kill this one.Steam will kill it if anything else can't.. SAMSUNG Terrace when it launches.
Yes i have gone through all these. It's nothing groundbreaking to have a tv in a high end bathroom, in fact quite normal. But the thing is my designer was asking to import it and it'll be costly. So i was hoping if i could manage that personally, here, locally. For now i ll get a cheap tv, if i manage to kill it, i ll have to go the expensive way.
