Price Thread: Stabilizers:CVT, Servo, AVT
madbullram
Chennai, India
Guys,
Collatiing price for Servo Stabs:
Update 18/Dec: Added Krykard prices
Update 22/Dec: Added revised Krykard prices
Alpha Power Corp​
This is a special price for HFV Members. For more details or queries call them. Servo controlled voltage stabilisers in single phase input and single phase output (with analog meter) with RFI/EMI filters:
1 kVA Rs. 4450 + VAT @ 4%
2 kVA Rs. 5000 + VAT @ 4%
3 kVA Rs. 6000 + VAT @ 4%
5 kVA Rs. 8000 + VAT @ 4%
(The RFI/EMI unit is inbuilt alongwith the PCB instead of a separate component)
If you want digital display, add 450 rs extra.
Isolation Transformer :
01. 1 kVA isolation stabiliser Rs. 4700 + VAT @ 4%
02. 2 kVA isolation stabiliser Rs. 5700 + VAT @ 4%
03. 3 kVA isolation stabiliser Rs. 6800 + VAT @ 4%
04. 5 kVA isolation stabiliser Rs. 9300 + VAT @ 4%
They have shipping to various cities and support in major cities. This comes with Comprehensive 1 year warranty.
Contact person: Mr.Gopal, VP - Alpha Power, 98408 20316
As always, when you call him refer HiFiVision to get this price.
Update Dec 17: Pics posted of my 3 KVa at http://www.hifivision.com/audio-vid...ad-stabilizers-cvt-servo-avt-3.html#post96203
VERTEX Stabilizers:
1 kVA 1 Phase - 10500.00
2 kVA 1 Phase - 12500.00
3 kVA 1 Phase - 13500.00
4 kVA 1 Phase - 14500.00
5 kVA 1 Phase - 15500.00
The above prices are inclusive of VAT 12.5%.
Optional Features:
Surge / Ligtning Arrestor ( Advanced version)
COntact Person: Manjunath Kalmath - M: 98860 81610
Website: Universal Electronics - Home
Alacrity - KryKard Stabs
Alacrity ( Welcome to Alacrity ) makers of Krykard Stabs.
KRYKARD 1- phase air cooled Servo Controlled Voltage Stabiliser, with RFI Filter / Spike Suppressor & 15A Plug & Socket:
Update 21/Dec from Alacrity: We have reworked the prices of accessories supplied along with the Stabilisers and are also offering a special discount of 7.5% to members of the Hifi Vision Forum.
Stabiliser Rating List Price (Rs)
1 kVA 8,600
2 kVA 10,100
3 kVA 10,900
5 kVA 12,100
Discount - @ 7.5% on the above prices
Packing - Crate packing at extra cost of Rs. 350/- for Stabilisers delivered outside South India.
Excise Duty - @ 8.24% extra
Sales Tax VAT/ CST @ 12.5% on above
Contact Person: Sudesh Kumta, Head- Business Development, Mobile: 93801 13296
Re: Stabilizers:CVT, Servo, AVT Price Thread
Update 18/Dec: Added Krykard specs
Alpha Corp PowerSafe Servo
Technical Specifications:
Input Voltage : 170V-270V,140V-270V
Output Voltage : 230V+/-1%
System : 1kva, 2kva, 3kva, 5kva, 7.5kva, 10kva, 15kva, 20kva (Air Cooled)
Connections : L N E
Operating Frequency : 47Hz-53 Hz
Output Voltage Adjustable : 220V to 240V
Output Voltage Regulation : +/- 1%
Overload Capacity : 110%
Correction Rate : 35V per Sec.
Waveform Distortion : Nil
Output Waveform : Reproduction of Input
Insulation : Class B or Class F
Short Circuit Percentage & Period : 100% 10 Sec
Normal Operation Temperature : 35 ?C
Climate Conditions : Normal
Type Of Cooling : Air Cooled
Mode Of System : Auto / Manual
Servo Motor : Ac Sync motor
System Construction : Constructed in sheet Metal Cabinet
Protections: Input Low, Input High,Output Low, Output Low,Time Delay, Fuse Protection for input.
Panel Controls : Press To Start, Voltage Selectorfor Input & Output.
Panel Indications :Mains ON, Output ON Input Low Input High
Panel Meters : Volt Meter to Read Input &Output
Input / Output Connections : 1kva 5Amps socket 2kva & 3kva 15Amps socket. Connectors provided 5kva to 20kva for both Input and Output
Optional Features : Electronic Overload & Short Circuit & Amps Meter
Physical Dimensions:
1 KVA 2KVA 3KVA 5KVA 7.5KVA 10KVA 15KVA 20KVA
L 330 mm 330 mm 330 mm 420 mm 520 mm 520mm 750mm 850mm
B 190 mm 190 mm 190 mm 240 mm 300mm 300 mm 350mm 400mm
H 270 mm 270 mm 270 mm 270 mm 340 mm 340mm 450mm 500mm
W 5 kg 6 kg 7 kg 13 kg 18 kg 25kg 40kg 57kg
VERTEX Stabilizers:
FEATURES:
1. Micro-Controller Based design.
2. User Settable features for High / Low cutoff / Output voltage / Auto / manual time delay, etc
3. Input range - 170 V - 270 V
4. Output : 230 V +/- 1%
5. Under / Over voltage cutoff - With graded time delay thru microcontroller
6. Overload cutoff - With graded time delay thru microcontroller
7. Built-in Double Stage EMI / RFI filter & Spike Suppressor (MOV)
8. LCD display - Reads I/P & O/P voltages / Output Current / Frequency
9. Input - 4 sq mm Cable with Lisha Plug top.
10. Output Lisha Sockets - 5 A - 4 nos.\
Alacrity's Krykard Stabilizers:
regulation range for Air Cooled 1 ph: 170V to 270V
Nominal output voltage: 230V 1%. Internally settable to 220V or 240V.
Note: change in output voltage setting will result in shift in input regulation range
Input frequency range: 47 Hz to 53 Hz.
Average correction rate: 35V per sec per phase
Waveform distortion introduced by regulator: Nil
Efficiency: Above 97%
Output voltage indication: Digital voltmeter with 1V resolution, 0.5% accuracy
Servo motor drive: AC synchronous stepper motor
Under /over voltage protection: Upper Limit - 12 2V above nominal, Lower Limit - 24 2V below nominal With graded time delay
Electronic overload cut-off: above 110% of rated output current with graded time delay
Spike Suppressor: MOV at output
Fault annunciation indications: Input present, output normal, input high, input low, output high cut-off, output low cut-off, output overload cut-off
Resetting mode: Automatic restart (Default setting 15 secs, can also be set for 3 minutes)
Standard Input & output terminations
Rating Input Output
1 kVA 1.5m long cable with a 5A plug Built in 5 Amp 3 pin socket
2 kVA 1.5m long cable with a 15A plug 15A Socket
3 kVA to 5 kVA 1.5m long cable 15A Socket
7.5 kVA to 15 kVA Built in 6 way terminal connector
Dimensions & approx. weight
Rating Dimensions (in mm) L x W x H Weight (kg)
1 kVA 301 x 236 x 305 23
2 kVA 301 x 236 x 390 27
3 kVA 4 kVA 301 x 236 x 390 29
5 kVA 301 x 236 x 390 32
7.5 kVA 360 x 310 x 520 71
10 kVA 360 x 310 x 520 83
Note: Any additional sockets, cabling or accessories required for installation of the Stabiliser will be in the customers scope
ervo controlled voltage stabilisers in single phase input and single phase output with Isolation Transformer
Hi Madhu,
Thanks for the initiative. Can you let us know what is the difference between the two models.
Which one will be good for AVR, Subwoofer?
Thanks,
Prakash.
There must be some basic difference between Alpha and Alacrity Servo Stabiliser. The 3 kVA Alpha model weighs only 7 kg, whereas a 3 kVA Alacrity (Krykard) model weighs 29kg.
And also the pricing is also half. If possible, ram, check the internals by visiting their factory.
Ajith: Me and Venkat where just discussing about this. I will try to get some pictures of the Servo so that we can compare. Also, I am trying to see if we can get hold of some expert in chennai who can give us an expert neutral opinion. But the specs seems to same as Krykard (Alacrity) so I am thinking must be some mistake.
Kumar/Prakas: I am def not Madhu, you can call me Ram or MBR def not Madhu :)
Ram,
Please post your Price list/Detailed descps. in order continuosly( insert from your second post, third post , fourth post....)... That is better, dont want to see inbetween the discussion... Or not possible to insert now, make sure to reserve some post for U in order..
Ram, were you able to establish the reason for the differences between Alpha and Krykard ? Looking forward to know your findings as i am very interested in finalising one by next week if everything is fine with those Alpha stabs. This thread is so helpful in the right time. Thanks for starting this thread.
swami
I got a Servo stabilizer made by a local stabilizer manufacturer in Noida about 2 years back. It serves my purpose but I am sure it is not very good quality. It is 2 KVA but rather big and heavy but very cheap.
What i did was I gave him a Hubbell Receptor to put in the output section instead of Indian type of socket. I think that makes a lot of difference. This time I am going to replace Hubbell with Oyaide or wattgate and I am sure it will make a positive effect.. If power cord of the servo can also be improved along with internal connecting cables it will be much better.
swami
Swami: I went ahead and bought a Alpha 3KVA. Its working fine at the moment. The reason they said is that their new processor controlled design much more advanced and reduces lot of components and more efficient, which is why the difference in weight.
Now, I am trying it on my own R&D. I cannot validate if it is true bcos I am no engineer :). I did check the output and it was a constant 230V and I also realized my house the power is very good. I get btw 230 to 240 so the servo did not make a difference in SQ or PQ. But I have peace of mind.
if anyone who is expert ion this can help, I can get them home and let them see the stab :)
Pictures please. If possible, the internals..
Ram, very helpful. My place in Chromepet, the voltage sometimes is pathetic, so, this will safeguard my equipment and as well better the SQ, hopefully. thanks again.
swami
