17" laptop
shrjun
Secunderabad/Singapore
I'm looking for a 17" laptop(desktop replacement).Budget - approx Rs.60,000(could be stretched)
Primary use - playing high def movies , music (ALAC files),gaming is not that important.
A good service network is essential.
Preferably an i5 processor.
HDD space not important as I have plenty of external storage solutions.
Is it possible to get a Bluray drive in this price range?
acer 5742g for 39k..
core i5
500gb hdd
4gb ram,
1 gb dedicated graphics card (ati)
hdmi
wifi n and lots of freebies..best deal..
however another model of asus is available for 67k and a good combo.. as stated above
however u stated gaming not that imp.. acer for 40k but is not 17in.
also a suggestion netime u buy a laptop its shud be for mobility.. 17 will be heavy...trust me u will start disliking that size.. people are moving towards compact..
and if you gonna use laptop at home only... upgrade you CPU.. my few words..
cannot agree with you more, made a mistake of buying a vaio 16.4" 2 years ago, thinking as a desktop replacement, but now that is quite a pain(literally) to move around
My reasoning for the 17" was that my current Compaq(almost 5 yrs old!) has literally sat on my workdesk immobile for the past 2 yrs(I don't need to carry it to work).My speakers are also attached to it permanently.Is it then advisable to just get a HTPC built to my configuration?However,the new notebook would also replace the ailing compaq which might be in the conking off stage:sad:
Could the best config be suggested for the quoted price range?
Sorry, I don't understand.. how can a laptop be more of a pain to move around than a desktop??
Yes, a large laptop will be heavy and not that portable, but only compared to a smaller laptop. There's no way it can be compared with a desktop which permanently occupies a large desk in your home. If you calculated the permanent space occupied by a desktop v/s the rental cost of that amount of real estate, that alone justifies the additional cost of a laptop. IMHO, the space saving and portability that a laptop provides simply cannot be matched by a desktop - you can lock your laptop away when not using it, you can move it around to different rooms if needed, and there are far fewer wires to deal with.
If ergonomics is a problem, there are other solutions as well like laptop riser, and wireless keyboard and mouse.
Back to the OP's question: I would strongly recommend a Sandy Bridge CPU paired with an SSD (at least for the OS) and/or a 7200rpm HDD. Sandy Bridge CPUs also come with an inbuilt GPU which has a dramatic performance boost - should be more than sufficient for hi-def and light-weight gaming. This will give you better performance than almost any desktop.
In terms of brand, I would always recommend Thinkpad for its durability, engineering, and keyboard. However, there are plenty of other options nowadays. It might also be worthwhile looking at the corporate versions of laptops (usually targeted at businesses) as they are most often better built and come with lesser pre-loaded software junk.
Edit: You can read a review of Sandy Bridge's mobile performance here.
To quote from the article:
"Not only do we get 50 to 100% better performance than the previous generation high-end Intel mobile chips, but we also get more than double the integrated graphics performance and battery life in most situations should be similar to Arrandale, if not better. And thats looking at the quad-core offerings!"
"In summary, then, Sandy Bridge improves laptop and notebook performance to the point where a large number of users could easily forget about desktops altogether; besides, you can always plug your notebook into a keyboard, mouse, and display if needed. About the only thing desktop still do substantially better is gaming, and thats largely due to the use of 300W GPUs."
Yes, a large laptop will be heavy and not that portable, but only compared to a smaller laptop. .
I wasnot comparing with a desktop, although mine is stationary most of the time i need to carry it around for trips that is usually once in month
yes it is heavy and with less back up compared to smaller ones, i went for it because of the specs, but eventually it wasnt enough for me and ended up with a worksation in my signature and alsoa netbook for portability and more backup making this one an expensive redundant
but original poster now says he aint going to move it , then probably ok
Are these CPUs available in notebooks in India at the moment.The review seemed to be about a pre-production model.
Coming back to my question - I am not bothered about the portability factor.However,good reviews and the best possible configuration with regard to future proofing(next 1.5 -2 yrs) would be nice.
I'm not too sure. I do know that it is officially shipping to vendors, and vendors already have models ready but am not too sure about how things are in India. However, it is worth finding out and waiting a bit if needed, as this belongs to a new CPU family that just launched, and offers a very big performance boost at the same power consumption and price levels (at least for the lower-end options). So, your future proofing will be taken care of.
If I may give a different kind of suggestion, have you looked at options in Apple?
Borg, sorry I misunderstood. I personally use a 15" Thinkpad T500 at home and am very happy with the performance and portability (at least inside the house).
