2.1, 5.1 or HTIB:Budget 50k
kkdeep
I am a newbie. I already have a projector and looking for a HT system.
Honestly I do not know what i am looking for. I just want a better sound than my in built speakers of projector (!). I do not want care about very loud system and typically watch things in low volume. So as long as sound is "clean" i should be fine. Also my budget is quite low. Assume < 50K total including UPS. My usage is 50:50 for Music/Movies and limited.
1) Probably a HTIB suits me. Any recommendations?
2) Somebody suggested Pioneer VSX329 AV Receiver Looks like this receiver is out of production. VSX330 seems to be the successor. is it any good? I see it has only one HDMI output. Is n't that a big disadvantage if the HDMI port goes bad?
3) Please recommend speaker model as well. Can not use floorstanders because it is not a dedicated room.
4) How about speaker placement in the layout. I need to plan for internal wiring as the house is in interior stage. Following is layout of the room. I have marked the screen location. The room size is 18 feet by 11 feet
5) I am also open to 2.1 system for now. I would have been on with a second hand system too but do not have time to hunt for it.
6) Which are the recommended shops to audition in Bangalore? I checked out Harman today in Phoneix market city but the model was out of budget.
7) Any recommendation on the UPS model? I just need time to switch off the projector
8) How big should be the storage for UPS/AV. I am planning to integrate it in the wardrobe (lower 3 feet).
Sorry about long post. Appreciate any inputs.
What is your source? If it's a computer, then you can check one of the many options of creative or similar brands. Else you can also see a Yamaha htib units.
MaSh
Sent from my Redmi Note 3
MaSh
The source would be computer. Any specific model for Yamaha/Creative that you would recommend?
Does anybody know any dealer in Bangalore where I can audition. Do not want to buy without listening. If i don't like HTIB, i would stick to a 2.1 or stereo system in my budget.
Given than it is your bedroom, I suggest avoiding traditional 5.1 speaker systems (and associated wiring issues) and go for a soundbar
You yourself say you arent ALL that particular about having "audiophile" sound
Plus soundbars are a very convenient solution. The subwoofer on almost all new soundbar systems are wireless and hence can be placed anywhere in the room. And quite a few models come with Bluetooth etc
Models - the Sony/Philips should be in 20-30k range and some of the Sony models are quite good, so definitely listen to them
If you want audiophile brands, then Polk/Boston Acoustics/Wharfedale etc also have soundbars available, but they might be slightly higher priced
Ok. In my opinion, if it's only to improve the sound and it's for a bedroom, I would not suggest a 5.1 system. Try getting a pair of good stereo speakers such a Swan D1080 costing around 12k. You could also check out Boston acoustics xs2.1 costing around 15k. These have really tiny satellites and a very capable sub woofer.
My father in law uses a Panasonic HT 20 which is a 2.1 unit with his TV and loves it. It actually sounds really good with both music and movies. Accepts a USB input too.
MaSh
Thanks!
I had rules out soundbars as there is no TV in this room and i thought soundbars are mainly used with a TV to save on wiring/space etc. I have just a projector. Also there is no problem in wiring etc as interior work is still going to happen. I will try to find a place to audition soundbars. Not sure where to find Polk/Boston Acoustics/Wharfdale in Bangalore. I guess Google will help.
Thanks!
Polk is carried by Pro FX, so you should be able to listen to them there
Sent from my STV100-3 using Tapatalk
MaSh
Thanks!! Swan sees to have great review at Amazon. So does Boston Acoustics XS2.1 but they seem to be discontinued but i have not looked hard. I will try to find a place to audition. I guess i won't need a AVR with these options.
General question, Is there place in Bangalore which deals with multiple brands to audition? I visited Bose and Harman over the weekend and both are out of my budget.
I doubt you will be able to audition either of these. You could visit pro fx for Polk and Kef, DNI for Dali, HT store, blabber, etc.
MaSh
