32' LG LE5500 or Samsung C 5000 or Sony EX 600?
sandeepgarg
Ajmer
Which to go for?
!. LG 32LE5500 Rs.36,000/- (or Rs.43,000/- with Blu Ray Player)
2. Samsung 32C5000 Rs.38,000/-
32C6900 Rs.53,000
3. Sony 32EX600 Rs.41,000/-
32EX710 Rs.48,000/-
All of these come with some sort of DTH offer (Which can be further discounted at about Rs.500-1000/-)
I will be needing 2 of them.
Do not spend huge monies on 32 inchers as you hardly notice the PQ differences. Go with VFM stuff. You can even try picking from gray market since you need two of them.:)
I have Sony 32EX600 and haven't connected to any DTH. With just the normal cable connector (Rf pin), the picture quality is good.
I can't compare with other models as I havent seen this with other models. But I will tell you what I felt about this Sony.
as far as the PQ, you dont need to explain more for Sony.
32" seems to be very small. Better go with atleast 40". you will feel once you install it in your home.
32Ex600 has loads of feature, DLNA, ethernet connection, internet, USB input plays even the HD formats too like mkv/m2ts etc.
using DLNA serviio console, I can stream wireless from my laptop to tv.
viewing angle matters. otherwise you will notice a glare in the PQ.
good pricing in the LED range.
sound is not bad but not good.
auto tuning is good, but when manual setup, its very horrible, scans very slowly.
Overall this is a good one on the lower range of edge lit LED's.
I can't fit a larger one in my room!!
Kittu, can u suggest me a good 32" VFM TV? LED or LCD?
Is the LG not worth it at the price?
Do advise!!
Do advise!!
LG LE5500 is a pretty VFM model you can even check 4600 series see if it can save you some more money. @ 32 inch you can see 480p as 1080p...:lol: can not really makeout much difference so try go for one of the models.
Agree with u Kittu. Go for LG LE4600 - it's total VFM and a plus point is it's excellent sound quality.
