32" Panasonic LEDs
pvsabnis
Pune
I'm planning to buy 32" LED TV for my small house in Pune. Shortlisted two Panasonic models namely:
1. TH-L32E5D (Full HD)
2. TH-L32X50D (HD Ready)
Please suggest me whether they're good or not. Also I'm confused between Full HD and HD Ready. In 32" will it make difference??
for 32 inch theres no need to go for Full HD. You will hardly notice any difference. Check out Sony models also. Go to a multi brand shop and make a comparison.
Sony LED TV KLV-32EX330 has Motionflow XR 100 Hz. Good if you watch a lot of sports.
Pana has 50Hz Panel Drive
I think you shoul go for Sony. Pana is for Plasma.
Well i own Pana TH-L32E5D.Good value for money led.price of E5 has come down.check flipkart.
it is priced around 35k only, compared to the last month price of 44k.
I would go further and say that you do not need LED TV even. An HD ready LCD tv will do fine at 32".
Sent from my GT-I9100G using Tapatalk 2
How about Sharp...?? I saw their 32" model....but it has only 1 HDMI Port. Is it recommended....??
Single HDMI port can be irritant but not something that is permanent disability. One can buy multi-port HDMI switch for the purpose.
Yeah but Sharp is selling for 25K....can we add HDMI splitter to Sharp LC-32LE341M?? Will that harm PQ...?? Also I can't figure out whether this TV is Edge LED or Backlight LED.
Splitter is used to split HDMI signal, i.e., one in -> two or more out.
The switch is exactly opposite, i.e., multiple-in -> single out.
For connecting to TV with limited HDMI ports from multiple source, one needs a switch.
Be it splitter or switch, the PQ is not affected as long as cable length does not run beyond 50m. At those lengths, HDMI may just stop working. HDMI is disgital - either it works or it does not work.
@just4kix.....thanks a lot for the info. Any idea about particular Sharp model.....is it good or bad?? only one 1 HDMI port should not be an issue I guess.....:)
Hey guys today I chked in Croma
1. Sony EX550
2. Pana E5D
Though colors of Panasonic was more natural to me overall BRAVIA's clarity was par with VIERRA.
Again confused which one to buy......
1. Sony EX550
2. Pana E5D
You said Sony was on par with VIERA(Panasonic), so go with panasonic.
