35mm film negative scanning in Bangalore?
raj
I have a bunch of old 35mm negatives that I want to scan into jpeg format. I tried GK Vale in Fraser town but the output was not satisfactory (some of the negatives are horribly over exposed while others are ok). Does anyone know of a good place in Bangalore to scan the negatives? Thanks.
Hey Raj...just saw this post...not sure if you are still on the lookout but if you are, you can try Prakash Digital Labs on Brigade Road (opposite 5th Avenue). I have got it done from them in the past, not sure if they still do it but they are your best bet...
That's a good idea to convert negatives. How do they charge per film?
