3D Projector dilemma
ashish.s
delhi
I am thinking about buying a 3D projector for my room. Looking at the Sony HW30ES and Panasonic PT-AE7000U. Any other suggestions?
3D projector for your room? Is your room the size of a conference hall or multiplex?! Just buy a big screen 3D TV as that would be enough.
Best 3D performance will be a DLP projector. Next is Epson TW6000/Panasonic.
Stay away from JVC if 3D is important. Those are known for ghosting and dim picture.
I own a JVC RS-45 and I will also suggest you to stay away if you are interested in 3D. Ghosting is very visible and for me its not watchable. Picture is bright enough though.
But for 2D it will be hard to beat it at the price point.
You haven't mentioned how important is 3D for you though. I was in a similar situation as you are. I wanted to buy either Benq W7000/Epson 5010/Panasonic AE7000 (Best of both worlds). But after the demo, it was a no brainer to buy JVC.
Don't buy without a demo no matter whichever you are buying.
If 3D is a must, go for Benq W7000 since it is DLP and it is cheaper than the competition.
And if you want to decide between panasonic and Sony, I will suggest Panasonic because of the lens memory. It is pretty cool and is something that cannot be ignored. Even more so if you are a movie fanatic. It is pretty hard if at all possible to find a projector which has everything at this price point.
Benq 7000 & panny ae7000 are both 2.25lacs... Jvc rs45 is in the range of 3-3.5 lacs... Epson tw8000 on the other hand is 1.40 lacs... We are discussing totally diff projectors in vast price ranges... Tw8000 beats all the rest in the price to performance ration atleast here in India...
+1 tw8000 beats all of the above hands down.
