42lm6690
Going to buy tata sky hd tomorrow.can u please tell me the coast?
TataSky HD will cost 2599 for STB+standard installation and then package will be as per your choice. There will be Rs. 100 as HD access fee per month.
I will suggest Videocon D2H instead which you may find cheaper.
Thanx.i checked both TS & d2H but i didn't find much difference.Price was looking same.(165 for HD Universe + any basic pack 150)
What is the difference between LM7600 & LM 6690 ? Which one is better ? Did you get with Diwali offer? BDP 420?
The major difference is that LM7600 has a native 120hz panel while all models below it have a native 60hz panel. LG uses clever algorithms in their TV's to boost their ''perceived'' refresh rates. LM6690 is marketed as a 120hz model but in reality it has 60hz panel. LM7600 has better black levels and also has local dimming executed better. If you ask me it is better to go for the LM6200 if you are on a tight budget or go for the LM7600 if you can afford it cos its genuine 120hz refresh rate helps you while watching fast paced scenes and also gives a boost when it comes to watching 3d. Sadly the LM7600 is overpriced a tad.
Why compare LM6690 to LM7600? I think it makes more sense to compare it to LM6700. Anyway, between LM6690 and LM6700 - not much difference in features - they are even priced the same, only the TV stands look different - the LM6700 sports the new ribbon design. The magic motion remote is constant as it comes with both the models.
In comparison to LM6690, LM6700 and LM7600 are the ones more heard of..But hey, congrats for the new purchase! :)
Congrats. Price? Post pics when installed.
Hey sorry Bro couldn't post pic. Actually my PC was not working that is y i didn't upload any pic.I bought PC too which i assembled yesterday.I'll post some pics as soon as possible & very happy with TV. 3d is very smooth & enjoying it...
