Hi ihave cubetek himedia player capable of playing 4k all formats on sale section.please refer and ping me if interestedHi,
Please guide with a good 4k media player that supports Dolby atmos etc. Need to play movies with external harddrive. Each movie size between 30gb to 80gb.
One of my friend suggested Zidoo and zappiti.
Are your movies located on a server, or local disks are used. Now depending on your setup, the requirement will be different.Hi,
10pro has no added advantage regarding specifications.only advantage is hard disk can be kept inside it .it costs extra 6k compared to 5proWang to know zidoo supports streaming.
Iam in between zidoo 9c and 10k pro
So zidoo 9x is better than 10pro?10pro has no added advantage regarding specifications.only advantage is hard disk can be kept inside it .it costs extra 6k compared to 5pro
Iam in between zidoo 9x and 10 pro.Are your movies located on a server, or local disks are used. Now depending on your setup, the requirement will be different.
If your budget permits go for Zidoo
9x around 30 and 10 pro around 35.Iam in between zidoo 9x and 10 pro.
As many suggested zidoo is better than zappiti.
In that case better you go for nvidia shield pro.its the best one you can have.9x around 30 and 10 pro around
Where in Mumbai, can I buy these? Thanks.Are your movies located on a server, or local disks are used. Now depending on your setup, the requirement will be different.
Where, in Mumbai, can I buy the NVidia Shield Pro? Thanks.In that case better you go for nvidia shield pro.its the best one you can have.
