Hi Guys,
I am looking for projector do I need go for short throw or long throw, do I need ALR screen these are the questions.
Situation : Presently, I have very odd room 10 X 14 feet on both side walls 1 door on left and 2 doors on the right and back wall is open as I have stairs this is on the first floor. future planning to build dedicated ht room I have open space 14 x 22 feet.
I was initially planning to buy Formovie Home theatre ultra short throw projector, I didn't get option for demo, I am not sure if I require ALR screen as home theatre room is not dedicate I do have ambient light except in the evenings.
Now my search is on regular throw native 4K projector, I can use for the present room setup, later I am planing to build a dedicated home theatre which will be 14 feet W and 22 feet L. need advise on projector, receiver and room acoustics. I want avoid fiberglass and other hazardous material and looking for cheapest solution DIY Acoustic Wall panels.
Anyone who owns dedicated home theatre share your build experience this can help.
1.4K Native projector which has option to lens shift for Cinema scope
2. AVR which can support Auro with 13.2 channels
3. Do I need AMP
4.What acoustic material I can use for DIY
3. Do I need AMP
