Mantu babu
Want a 5.1.2 tower speaker pakege for denon x2700 avr plz sugeest under 1lakh
welcome to HT world, 1stly need to understand what is purpose like movies or music , how much u use for movies & musicWant a 5.1.2 tower speaker pakege for denon x2700 avr plz sugeest under 1lakh
Hi I suggested Polk audio or Monitor audio, please try for monitor audio a bit better than Polk.Want a 5.1.2 tower speaker pakege for denon x2700 avr plz sugeest under 1lakh
This is one of the options worth considering within your Budget. You have to add the ATMOS speakers separately.Want a 5.1.2 tower speaker pakege for denon x2700 avr plz sugeest under 1lakh
I had taken a demo of these while searching for my front LCR. They are value for money , specially the towers. They are good for movies. For music I think you may be better served by other speakers.These.. r good??
How were Eltax and which model did you audition? Any comparisons?Check with surroundswar. They have introduced two budget brands Eltax and tangent. 5.0 tower package 35-48k Mrp. So with discounts it will be much less. You can invest the remaining amount in a good subwoofer. I have auditioned eltax and for its price it was decent enough. Taga harmony is the budget champ and forum favourite which is also available in your budget
Tangent Aspect 5.0 Speaker Package – surroundswar
surroundswar.in
Eltax explorer. I just had a short demo and it was just plug and play. It was not calibrated and connected with a Denon 2500. It sounded decent and should be even better after room corrections.@
Please contact www.avmatters.inThese.. r good??
