5.1 for 17 x 11 feet room
nmrajarajan
Coimbatore
Hello,
I am planning to set up a 5.1 home theatre. I am also planning to upgrade it to Atmos (5.1.4 or 5.2.4) in the future.
I have selected the followings although i have not finalized anything.
Front Speakers: Yamaha NS-F71
Surround & Centre: Yamaha NS-P51
AVR: Pioneer VSX-LX303
Room size: 17 x 11 x 10 (height) feet
Will this work?!
Also need your suggestions/recommendations regarding subwoofer.
Hello rajarajan.. Welcome to HFV ..!
Whats your budget ?.
Pioneer VSX-LX303 is good to go - good AVR with features for the price.
Did you audition above Yamaha NS-F71 speakers?.
Center channel you can pick better speaker.
You also must get one 12 " subwoofer or (two) 10" sub woofer. Having dual sub woofer have more advantages.
You can also audition : Polk , DALI, Monitor audio , Sonodyne , Kilpsch..etc.
Hello,
Thanks for your reply.
No, I have not auditioned any of the speakers. I am currently reading reviews and deciding for audition.
Could you suggest any other model?
Regarding the centre speaker, the one, I have selected, comes as a package. If I have to look for others, which one would you suggest?
My budget is 1.5L
Welcome to HFV!
With that budget, you can look at a variety of speakers .....
There are dedicated Owner threads of Taga/Yamaha/Pioneer/Marantz/BIC America/Denon etc which you can browse and read actual feedback from users there.......
Speakers you can look at Taga, Polks, Pioneer (Andrew Jones), Boston Acoustics (Blends with most AVRs),
Subs - Sunfire / BIC America / SVS / Polk / Boston Acoustics / Taga / Yamaha.....
Dont rush and never reveal you real budget to the dealer....go window shopping where possible / see Youtube videos to get an idea and then decide
Welcome to HFV!
Could you suggest some model numbers fitting my budget?! I am a newbie and I have very less idea about what will suit my room.
My preference is clear audio (instruments) + good bass.
Surround & Centre: Polk T15 & T30
Subwoofer: 2 x PSW10
Hello, any opinion about the above combination?!
Alternate options for the front speakers
1) TAGA Harmony TAV-806F Floorstanding Speaker
2) Boston Acoustics A 250 Floorstanding Speaker
