50inch(or above) Passive 3D under 1lakh?
srinivas1015
India
What are some options for Passive(polarized) 3D TVs (Full HD) under 1 lakh? The minimum size is 50inchs but if anything bigger is available, that would be awesome.
I'm open to Plasma and LED tech.
For the moment, the only passive 3D (LED) TV manufacturers are LG and Panasonic (one model only, viz. ET5D). This is likely to change with Sony's 2013 TVs. LED TVs come in 46" and 55". But it will be difficult, if not impossible, to find a 50" (read 55") 3D LED TV under 1 lakh.
Most other 3D TVs - be it plasma or LED - use the active 3D technology. In the LED range, again it will be difficult to find a 55" TV under 1 lakh. If stocks are available, you can get the Panasonic plasma P50ST50D for little under 1 lakh while the plasma P50GT50D will be slightly over. Plasma will yield better PQ and natural colours while LED will yield oversaturated PQ and colours. Choice is yours. Both technologies have pros and cons. Plasma is susceptible to IR and a little more prone to reflections, while LED will result in soap opera effect, LED light bleeding, and motion judder.
