HEAT is the biggest enemy of Electronics if it is not properly ventilated.Let it be AVR or Stereo/Integrated Amp.
I am not discussing about water heater/ warmer / toaster /OTG which are meant for heating purpose
just curious, is cooling fan really necessary?? How hot can an AVR get over a movie or two continuously. Can it build up so much heat that it start to fail?
Yes.
in AVR there are chances of HDMI board failure if it is not properly ventilated.
I have actually run a class AB as well as a Class A amp continuously for more than 7 hours, and once I have even slept off with the amp on all night and I have not seen it give up on me.
Dedicated Stereo amps/ IA /Poweramp have properly designed heatsink for amplifier section. Other than amp section there won't be much heat dissipation inside the enclosure may be slightly from powersupply section. Even AVR has heatsink in amplifier section but not for other modules (eg- HDMI section,power supply section ).
AVR - It is cramped with lot of components inside a small enclosure and it does lot of things.
Yes there are compromise in Heatsink thickness /size /design in basic model AVR.
Compared to Non HDMI model AVR ,HDMI model has highest failure rate due to complicated design and above mentioned factors.
So in that case why add an external cooling fan ?? If an AVR needed an external cooling or alternatively a fan, the manufacturer would have given it as a standard offering.
There are cooling fans inside AVR in mid/highend models ,and it is placed near power Amp section that too available only on few models /brands.
Earlier days there was a myth ,that everone would have come across looking for spike buster/ buying spike buster for their TV to avoid spare part failure due lightning which cost 25rs.Why cant Tv company provide this spike buster as standard part of Tv!? Similar to stabilizer market !!!
Coming to your query
Why they are not giving as standard ? - If there is no spare part failure.No business from the old AVR unit .. simple
Hope u got the right info.
External Fan is necessary to minimize the chance of hdmi board failure.
PS - I own and run 2 MARANTZ AVRs Under Aircom
infinity T9.
it keeps the AVR Cool.
