A travel companion - Apple IPod 5.5 Generation.
Bought a ipod from olx very long time back. Then dint use it for a very long time...like a year or so...then one day it caught my eye and when i switched it on it was logged out...not able to trace the buyer from olx chat...any help??
Please give the instructions that how to upgrade the storage & battery. That will be helpful. Thanks.
Great to know. Could you please guide on how to change a battery and upgrade memory.
There are a lot of sellers on OLX where you can purchase batteries. Also, the storage can be upgraded by removing the HDD and installing a ZIF adaptor or iflash adaptor (an adaptor specially made for storage of iPod Classic; iflash.xyz). The replacement is pretty DIY, just remove the back panel, remove the battery clips and insert the new storage. There are various youtube videos too available.
Thank you so much. Will try
Did you buy one that was white with black wheel?
