A way to angle the speakers..?
MiG117
I have a Energy Take speaker set. The surround speakers have been wall mounted onto the sidewalls of the room, such that both the surround speakers face each other. I need a way to angle the surround speakers toward the seating area. Is there any efficient way to do this?
Looking forward to your suggestions.
You can try to buy something like this, this helps you turn the speakers
Jenefas | TV Stands | Wall TV Stands | Ceiling TV Stands
^^That looks neat. Since I am supporting the speakers through a nail in the wall, is there any such stand that can just be mounted onto the nail instead of completely nailing the new stand to the wall all over again?
Nails are absolute no-no. You may want to attach a thick board on the wall and then drive the wall mounts using screws.This will atleast give you flexibility to move things around when you change your system down the road.
Any particular reason for this? I guess the energy speakers are not rear firing.
Nails tend to not hold the mounts as snug as threaded screws (or so calllled concrete screws). this has the potential to cause a fair bit of vibrations in the speakers leading to disproportionate audition. A screw removes such problems.
And dont forget, screws are easier to insert and remove.
