Accessories for TT
AMITNOIDA
Noida
I want to have few basic accessories for Tonearm, Stylus and Cartridge fitting/alignment . Can you specify them and give clue where to source from.
The accessories to include the pliers, tongs etc along with Stylus gauge and so on..
Addition to above -
Bubble level like this
Long spirit level for TT
Carbon fibre brush like this
Lint free cloth like 3M car detailer.
Stylus cleaner - Magic Eraser, zero dust etc.
I think this is basic list of accessories to improve day to day listening of records.
PS: No affiliation with any seller.
Thanks Omishra for he list of items. I have already collected few e.g. Carbon brush, Stylus cleaner liquid, antistatic gun, Spirit level. Recently ordered a Stylus gauge and protractor.
How the Magic eraser works? I have heard its name but do not have any idea of its application. I plan to collect Onzow zerodust and your link is simply superb with zero shipping charge from Hong kong. Your link for heasdhell spirit level is also very helpful.
Over and above the above items what else like plier etc. will be required?
How the Magic eraser works? I have heard its name but do not have any idea of its application. I plan to collect Onzow zerodust and your link is simply superb with zero shipping charge from Hong kong. Your link for heashell spirit level is also very helpful.
Protractors are specific for each tone arm and cartridge. It's combination could be best aligned by specific protractor. You can read details on vinylengine.com.
Magic eraser is nothing but piece of sponge with tiny pore and patterns like thin spiral of paper role. This could not be seen by eye.
You have to cut thin piece of it by size of 1"X1" and 3-5mm thickness. Put this on platter and cue your cartridge onto this couple of time. This will take out dirt from that tip by gentle wipe cum scrub action. Whole magic eraser will last for life.
Plier, I never required with TT. Where do you think it may be needed?
I have a modified Rega arm in my TT. So Rega protractor may be a good utility. But due to my inadequate reading and knowledge I have purchased a protractor named "Tool Mirror' from Ebay.com. I don't know whether I will be able to use it at all for my Tone arm.
The plier, as far as I know may be required for connecting the cartridge wire. Please correct me, if I am wrong.
In the Ebay.com I have seen that Onzow Zero dust is sold at about 25 USD plus shipping charge of about 16 USD - total about 41 USD. Are these genuine? Whereas Onzow Zeroust is sold at 68 USD plus shipping at Elusive disc, Needle doctor etc.
That seller for zero dust was referred by Malvai also. I don't have personal experience with that seller.
If you are not planning to drill a new hole for a new tonearm, you can get away with:
1) the stupid protractor downloaded off vinylengine - print to scale, stick transparent tape, cut the spindle hole, and use for null point alignments. Extremely useful tool.
2) a 6 inch steel ruler accurate to half mm to measure and adjust cartridge overhang. In my limited experience, I find that the overhang doesn't have too much effect on sound quality. If you can get roughly about 15.3 mm or so, it works fine for most cartridges.
3) spirit bubble to measure if azimuth is right. This must be small and light enough to be mounted on top of headshell. Closing one eye and eyeing the headshell-cartridge combo from the front of the cartridge with the open eye, taking due consideration of parallax, also works quite well for checking azimuth. Anyway, this is moot if your arm doesn't allow azimuth adjustment.
4) a long spirit level to check if your table is level. This is often over looked but a critical foundation.
5) a set of allen keys to unscrew/tighten counterweight, antiskate, etc (you may not even need this depending on your arm model).
6) small flat as well as star screw drivers to loosen/tighten headshell screws. As far as possible, I try and restrict myself from using screw drivers for fixing cartridges. Finger tightening is usually sufficient in most cases.
7) a small brush to periodically brush off dust and hair-like things accumulated on the stylus. The brush that comes with the Denon DL 103 is particularly nice. A gel like Onzow Zerodust is also essential. So is an antistatic brush to clean record surface.
8) adjusting your VTA - one time exercise, very useful. You may need some large wrenches depending on your arm model, but totally worth it. Use a 150 gms record to do VTA adjustment.
I too use the two point protractor downloaded from Vinyl engine. Print it to scale and paste it on a bad LP (badly scratched etc). The null points on the paper gets worn out with time, will stick some transparent tape as per Jls's suggestion.
The Onzow Zerodust is a must have. I got mine for 40 SGD. The transparent cover is a bonus - it doubles as a magnifying glass and it is very handy to check condition of stylus. Also, since it is square, it can be placed on the platter while we look through it to align the cart parallel to the lines on the protractor.
To add to Joshua's extensive list, I would also get a vta block like in link below. Apart from VTA, it works very well for checking Azimuth:
MILLENNIUM ACRYLIC VTA BLOCK at Music Direct
I am considering getting a few of these blocks made (to keep cost per block low), have checked with a few contacts and results are positive. Shouldn't be too difficult as long as one can etch the lines with precision at a distance 2.5mm.
Thanks Santosh, Sachin an Joshua for your exhaustive list of accessories.
What about wet cleaning brush? I have in mind Disc Doctor velvet brush and Nitty Gritty bristle brush. Actually I have recently purchased a Nitty Gritty used RCM.
For dry cleaning I have a carbon fibre brush and a Hunt type brush and they work fine.
