Acoustic foam and spray adhesive?
deepakvrao
Hi Guys,
I need to layer thick acoustic foam on the sides of my golf sim, so it's to protect against errant shots, and not really for noise insulation.
What is the thickest I can get? All I see on amazon is 1". Also, I see people use spray adhesives to stick it on to plywood? Would you guys suggest a spray or some other? If spray, which one?
Edit: Found this at 2". Still need suggestions for the adhesive though
