Advice for Denon X550BT which "trips" sometimes
vishalrao
Pune, India
Hello folks!
I have a so-called 3-phase protector device fixed after my electricity meter box that cuts off supply for at least 2 minutes for over or under voltage, and I have a so-called pure sine wave inverter for whole-home backup in UPS mode which works well for all my devices in the house - TVs, my HTiB set, my PC, smaller stuff like wifi devices etc.
I have a Denon X550BT which will sometimes "trip" (make a click sound while "restarting" or toggling itself off and on) when the inverter kicks in to switchover and switch back (during power cuts or voltage goes out of its UPS-mode range) which seems like the AVR's power supply is very sensitive.
Is there a quick/simple solution I can apply to prevent this? Like some devices have power adapters (bricks) that apparently retain some charge for brief enough duration to withstand the inverter switching delay (even though it claims to be under 20ms) so these devices continue to work uninterrupted.
Any advice or suggestions?
Thank you!
Cheap solution: get a servo stabilizer and connect to the AVR (1kva is enough if you only connect the AVR alone).
Costlier but comparatively better solution: buy a Static voltage stabilizer, where it's correction time is extremely less, ie: less than 10ms which would keep the voltage very stable.
I'm using the same AVR and faced similar issues several times in a day, which left us all really frustrated.
Then found a local provider who's specialized in making the servo stabilizers, and contact him and bought a 2kva, where I've connected the AVR and the TV.. after that things got great where i haven't faced any issues till now. It's been 2 yrs now, going great guns.
Spent 11k but really worthy. It's correction time is around 10ms.
Note: I'm staying in a semi-urban TN area where low voltage issues are very common. So accordingly I've got a high range stab (130v - 250v)...
@sivag08 I am also facing similar issue. which servo stabiliser (2kva) you got ?
Hi bro, mine is locally made one, which i sourced from a provider near me who did really well.
I'm from Trichy, TN.
I'll share his details, if you want you can check with him, as his org manufactures servo and other such equipments and ships to other states as well.
Contact:
09894633338
Ramesh
One thing which is for sure is - you'll definitely need one, and some of my friends also after a lot of failed attempts finally bought themselves a Servo, as these AVR s are super sensitive. :(
Hello All,
I am a Electronic Technician and here to help you for your issues/problems with your audio system.
Hello All,
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
