I am looking for an AV receiver for ELAC Uni-Fi Slim BSU5 Bookshelf pair. I have already bought the speakers.
1) Speaker specifications :
Speaker type: 3-way, bass reflex
Tweeter: 1 x 1-inch soft dome, concentrically mounted
Midrange: 1 x 4-inch aluminum cone
Woofer: 1 x 5.25-inch aluminum cone
Crossover frequency: 270 / 2,700 Hz
Frequency response: 46 to 25,000 Hz
Sensitivity: 85 dB at 2.83 v/1m
Recommended amplifier power: 40 to 140 wpc
Peak power handling: 140 wpc
Nominal impedance: 4 Ω; minimum 3.4 Ω
Binding posts: 5-way custom
Magnetic shielding: No
Cabinet finishes: White satin paint finish
Accessories included: Magnetic fabric grille
Height: 13.35 in / 339 mm
Width: 7.0 in / 178 mm
Depth: 11.54 in / 293 mm
2) Budget for AV receiver:
Rs. 50000 / -
3) Listening tastes:
Classical/vocal music listener, Jazz, Opera.
The system will also be used for viewing movies on TV with the stereo setup and may be later (at least a year later) upgrade to 5.1 system. ATMOS is not a necessary requirement. However i do require phono input for my turntable.
4) Listening / Viewing area:
The listening area is 11.5 (W) x 16 (L) feet, with a distance of 11 feet from the system / TV to my listening couch.
There is a open dining area of 11 (W) x 10 (L) feet adjacent to listening couch.
5) Location:
Gurugram
I wish i had additional budget, but its a constraint here at the moment. One of my concern is the given nominal impedance of 4 Ω, dont want to end up with an underpowered AV Receiver.
Looking forward to suggestions, Thank You.
Rs. 50000 / -
5) Location:
Gurugram
