Fantastic
Re: Getting a Berning amp
SE's would usually be more expensive than an 'equivalent' PP amp because of the cost of the transformers. They are much bigger too. More weight , much more money !
Tubes also need to be larger than PP for an equivalent power output.
Often with more complex winding patterns and that makes it even more expensive..then core types....etc.. Making a 'good' special SE amp means you start pulling out the stops where ever you can and the end result could be quite shockingly expensive ! But you could certainly make the PP far more expensive by adding on 'proprietary circuitry' and have 'very special parts'. Not to mention the extra charges for the idea ! This one claims "Harmonically sophisticated ". WOW that must cost a lot ! But what does it mean ? Ideal ( the best ) amps should have no self generated harmonics ! So this one is great because it does just that in a special way. One MUST listen to it. That would explain it all.
In the market you get eyeballs only if the manufacturer claims something special about it. Or it's a stunner visually . That works for 'anything' !
But blind listening tests can always tell you what it really is like.
