Hi Sandesh, not familiar with repair options in Bangalore. With regard to your NAK CR2, here is the list of original NAK heads for all NAK Models. If the Sendust head available with sarith is a NAK original, its serial number should feature here:
Nakamichi Heads:
BA04927 Head Assembly (TD-1200)
CA08311 GA01294 RP-9E Record/Playback head (480Z)
CA08137 P-8L Playback Head Ass'y (482Z)
CA08300 R-8L Record Head Ass'y (482Z)
CA08524 GA02216 R3LH - Record head, replaces GA02034 (BX-300)
CA08525 GA02085 P-8LH Std Trans Playback Head (RX-505)
CA08659 R-3L - Record head, 3.5 micron gap Crystalloy (BX-300, CR-5, CR-7)
CA08658 P2H-L, P-2H3L Playback head, 0.8 micron gap Crystalloy (BX-300, CR-5, CR-7)
CA08757 P5D Playback head (TD-300)
0G01365 E-2D (RX-202)
0G01371 RP-2G (RX-202)
GA00101 P53 playback head w/mount
GA00102 R-52 Record head w/mount
GA01050 R-8L Record head see GA02084 (481, 582, 582Z, 681ZX, 682ZX, LX-5, RX-505, ZX-7, ZX-9)
GA02007 R-52 Record head
GA02012 R/P-53 Record/Plaback head
GA02013 P-53 Playback head
GA02014 E-54 Erase head
GA02017 E-8L Erase head See GA02103 (480Z, 481, 482Z, 582, 582Z)
GA02034 P-8L Playback head See GA020?5 (I think it is GA02085) (481, 582, 582Z, 681ZX, 682ZX, LX-5, RX-505, ZX-7, ZX-9)
GA02039 See GA02012
GA02040 R/P Head-BL
GA02083 E-8LH - Erase head (680ZX, 681ZX, 1000ZXL, 1000ZXL Limited)
GA02084 R-8LH Record head See GA0221? (680ZX)
GA02085 P-8LH Playback head 680ZX
GA02101 See GA02132 (Playback head for 1000ZXL)
GA02102 See GA02133 (Record head for 1000ZXL)
GA02103 EOK Erase head (682ZX, LX-5, ZX-7, ZX-9)
GA02132 P-8LZ - Playback head (1000ZXL Limited)
GA02133 R-8LZ - Record head (1000ZXL Limited)
GA02162 PA-1L - 0.6 micro gap Crystalloy Playback head 4-track/2-channel-stereo (Dragon and maybe the TD-1200 also)
GA02201 E-4F Erase head (BX-300, CR-5, CR-7)
GA02203 P2C-3L Playback head Laminated-Crystalloy core, 0.8 micro gap(TD-400 TD-500 TD-700)
GA02217 R-3LZ Record Head for GA02133
E-2D - Erase head (BX-100, BX-125, RX-202)
E-8L - Erase head (ZX-7, 680ZX)
P-8L - Playback head, 0.6 micron gap width, Crystalloy core (ZX-7, 482Z, 1000ZXL, 700ZXL, ZX-9, LX-5, RX-505)
P-8LH - Playback head, 0.6 micron gap width, Crystalloy core (RX-505)
P-9F - Playback head, 0.6 micron gap width, Crystalloy core (670ZX, 680ZX)
PA-1L - Playback head, 0.6 micron gap width, Crystalloy core, 4-track, 2-channel stereo, split gap - 1 channel in each direction (Dragon & TD-1200 all versions)
R-8L - Record head, 3.5 micron gap width, Crystalloy core (ZX-7, 482Z, 680ZX, 1000ZXL, 700ZXL, Dragon., ZX-9, LX-5, RX-505)
R-3L - Record head, 3.5 micron gap width, Crystalloy core (BX-300, CR-5, CR-7)
RP-2D - 1.2 micron gap, Record/Playback head (BX-100 BX-125, RX-202)
RP-2G - Record/Playback head (RX-202)
P2C-5D - Hard-Permalloy core, 1.2 micro gap (TD-300)
The 1000 used a 0.7micron playback head and a 5micron record head. I don't know which P/N.
Also if would be useful to do an impedence match before changing the head if proceeding with an alternate option for replacement (and not the listed one).
On another note, suggest you have a read through the following page for a better understanding on magenetic tape heads:
JRF Magnetic Sciences: Tape Heads-An Introduction
Some NAK trivia, do you know where NAKs were actually manufactured? Here is some light on that front:
Where are various Naks made (from the website listed below):
From some of the replies to my query about Nak decks manufactured in countries other than Japan, I suspect that the lower grade decks were slowly phased into subcontracted manufacturing during the 1980s. By the 1990s, most Nak decks were manufactured in other Pacific Rim nations. In some cases, quality issues became an issue as subcontracting increased. Appears that the BX, CR series decks were done mostly in Taiwan, possible South Korea, and the late 1980s mobile components were done predominantly in Hong Kong. Here's a start to short list what my speculative chronology is for Nakamichi cassette deck manufacturing locations from the 1970s thru 1990s.....
Nak Tri-Tracer series - Japan
Nak ZX/ZXE/ZXL series - Japan
Nak LX series - Japan???
Nak Dragon - Japan (& later Taiwan???)
Nak CR1 thru 4 - Japan & Tawain
Nak CR5 & 7 - Japan???
Nak RX202/303/505 - Japan
Nak DR-1 - Japan
Nak DR 2/3 - Malaysia & Taiwan (S.Korea?)
Nak Cassette Deck 1/1.5/2 - Japan and maybe Taiwan & S. Korea
Nak DR 8 & 10 - Japan and maybe Malaysia too
Mobile Nak TD 500/700/1000 - Japan
Mobile Nak RD 460 & TD 560 - Hong Kong
Mobile Nak Amps - Japan & Hong Kong
Mobile Nak Speakers - Japan & Hong Kong
A one-stop shop for info on NAKs where I sourced all the info on this post, from (scroll down):
Scott's Nakamichi FAQ Page
Note on Sendust heads at this site:
The only deficiencies of the Sendust heads is bass rolloff at 25-30Hz, rather than 12-15Hz, and mildly depressed HF PB response(not so much on the 480/LX-3/RX-303), which is EQ'd on the record amp side in the BX & later 2-heads. The single capstan 2-head decks are less prone to lose HF with wear due to not having the pressure pad lifter, so the tape is forced into the wavy wear areas. I certainly agree that head wear is last place to look for HF loss, but in this 482 case, it seems fairly definite.
