ankitbhargava
Since I just have 5.1. I had been trying to use the SB channel amp for FS and this is the information I have got. Just confused if its must to run 2 set of wires as explained?
Any other suggestion?
FRONT A/B BI-AMP - Use this setting if you are running a 5.1 setup, and you would like to use the spare SB amps to bi-amplify your front speakers. Please note that you must have bi-amp capable speakers with FOUR speaker wire posts, and remember to remove the "jumper" connecting the posts or you will blow your amp!
In this setting, you will run one set of speaker wire from the FRONT L/R terminals on the Denon to the lower binding posts on your front speakers, and then a second set of speaker wire from the SURR.BACK terminals on the Denon to the upper terminals on your speakers.
