Dear Mr AFJ,
I will definitely not recommend such system to drive B&W Speaker. None of them will work. AV Receiver for home theater system is another different issue. First, what is his purpose buying all these equipments? To listen a music or to set up a home theater? For music use pre amp + power a very good one to drive the speaker, you may want to consider Krell, T+A Elektroakustik, Cyrus, McIntosh, Chord Electronics, Conrad Johnson, Mark Levinson, Audio Note, AMR, YBA, and many more. For home theater use, you may consider Denon as they are pioneer in home theater systems. If budget is concern please do not be in rush, playing all these high end audio component is not very cheap...why you are in hurry but satisfaction only for a short time. Just for your information, I spent more than 40,000 USD to set up my system properly and wait for quite long but the satisfaction that I have is very pleasant. Am not going to buy these equipments in hurry..no points. Setting up high end audio systems you need
01. Pre Amplifier (Tube or Solid State, it depends on sound you want to get)
02. Power Amplifier
03. Power Conditioner
04. Voltage Stabilizer (is a must since India voltage is up and down, sorry to say this).
05. Speaker cables (Materials determine the sound quality, the good one range from 3000 - 40000 USD per meter)
06. Power cords (Again is play important rule, good one range from 800 - 10000 USD per meter)
07. CD Player (using DAC or CD Transport definitely improve sound quality but it is very pricy, you may want to consider Naim CD Player and it costs around 13,000 Pounds)
08. Vibration damping for your systems,
09. A good Hi Fi rack.
so not just grab this and that.... it is not that simple.
Yudistira.
