Hi Guys,
I recently bought SMSL A300 and Q Acoustics 3020i speakers. I'm really enjoying the new setup, the sound was very good at low volumes under 30(Amp has volume upto 60). But when I crank the volume above 30 on the A300, the highs become piercing and it is unbearable in some songs. I even tried adding a tube amplifier to the chain but I didn't hear any noticeable change.
Before this setup I used Fosi BT20A with Micca RB42 speakers. Same case with that setup as well.
Now I'm thinking of buying DA-9. Will it be any better than the A300 or should I look for something else?
I use DAC 14 AWG speaker cable with DAC banana plugs. Shoul I change the speaker cables?
This is for the desktop setup so that I'm looking for amplifiers with small footprint.
