musiklava79
SENOLA PORTABLE WIND-UP GRAMOPHONE (Part 1)
The Gods must be smiling on me! The last week had brought a bounty of record players for me. While one was the Pioneer that I received from Mr.Shafic, the other was a huge windfall for me!!
The make is Senola, a music company that was based in the then city of Calcutta (now Kolkata) since the 1930's or earlier. The information is either unavailable or sketchy but I can safely say that its a rare find indeed as the company had become defunct sometime after 78 RPM shellac records went out of fashion. More about Senola later.
This is a very vintage wind-up gramophone that I picked up from an old radio repair shop. This machine was lying in the loft of this shop for a great many years. Although the machine looked quite decrepit in appearance, all the parts appeared to be intact and everything seemed to be untouched as there were no visible score or scuff marks on any of the screws. The machine was totally distended and the shop owner informed me that the winding spring was probably broken or needed re-setting. He did not try to repair it. The sound box worked and sounded alright. One could hear the sound very clearly when the bottom part was tapped at the point where the needle is affixed. The sound box is Swiss made and this is stamped on the part. The rexine cover was frayed and torn, the nickel plating inside was beginning to fade and there was rust/oxidation of other parts as well. Rust was evident in the cover hinge and the clasp lock. The wooden gramophone body and cover frame was intact and the timber seemed to be of good quality as all the corner joints had fine dove-tail joints of excellent workmanship. Only the cover had caved in slightly but did not seem the worse for wear. A closer look revealed that it was a piece of thick cardboard/hardboard. This can easily be substituted with plyboard.
There is going to be a long process for restoring this machine and plenty of time and energy will have to be devoted to this project without losing patience at any stage!
Here are some photographs of the gramophone.
The sound box. Swiss made!
The winding handle.
Excellent carpentry/workmanship. Note the dovetail joint!
The winding handle.
