any feedback on PM 7004
X man
There are limited reviews on Marantz PM 7004 on the net. Any feedback/reviews on the amp.? Are there better alternatives in similar price range.
if feedback is still required.
the pm7004 is the one step higher model of 6004 which has got many 5 star reviews. in addition it has mid level control, better transformer, more powerful and direct amp. I have placed the order for 7004 and expect that in 2-3 days. will share feedback
No experience with the 7004 but I've been using the pm7001 for a few years now and quite like it
There are always alternatives!! However marantz has been delivering some solid integrated amps over few years that are solid performers wrt sound, details and separation. 7004 biggest advantage over 6004 is frequency controls that can be adjusted manually. This is a great feature in any integrated.
@vkhandelwal - Please share what cost you had to incur, because I am planning to go with it as well
I could not find alternatives in similar price range and perfromance few reviews and sites also state that it is hard to beat this amp in its price range (6004/7004). there are few more advantage over 6004 which justifies it price over 6004, Like HDAM SA3, direct power amp, tritone control
Marantz UK | PM7004
I have received 7004 and it is pairing very well with my RX6.. I had also checked with Monitor Audio and below is the reply from them
Apologies in the delay getting back to you as we have had staff on annual leave
The 7004 should work in this function but it might not be a good idea to go any lower than this
The PM 15S2 might be a better match as it a more powerful Amplifier
Technical Services Department
Monitor Audio Ltd
Unit 2
24 Brook Road,
Rayleigh,
Essex
SS6 7XJ
Co Reg: 1161473
Tel: +44 (0)1268 740580
Fax: +44 (0)1268 740589
Hi-Fi Speakers, Home Theatre Speakers and iPod Docks | Monitor Audio
________________________________________
Congratulations ! Do please use A and B speakers to Bi-wire. I know it would ruffle a few feathers on our forum reading up all the articles. However this is also what Monitor audio guys adviced me and I tried this and have noticed a refinement and good seperation with my RX6.
I use the chord silver screen for the higher frequency + midrange and a heavier 2.5 dia copper cable for the lower frequencies.
Thanks will give it a try though my wife will not be happy as i will have to do away with speaker b which i am using for kitchen :)
PM7004s are great. I have personally heard them and you just cannot go wrong with them. Vocals simply danced on this amp though i would have loved a little more bass punch.
At the end it will depend on your taste and its synergy with the speakers.:)
Pm 7004 will easily drive wharf 9.1. Even pm 5004 is good enough for 9.1. I think pm 7004 is capable of far better performance and deserves better speakers.
Have you used PM7004 as a power amp using power amp direct in. for pre outs from ur AVR. Found the need to push volumes to close to -5db levels vs. -15-20db using AVR alone.
I am using the preouts to pm7004 with direct amp function. This is working fine for me as volume control is single
I have also connected remote out of sr5006 to remote in of pm7004. Can control the volume and switch off using one remote
you can try recalibrating the receiver if you are connecting like this or increase the input source level
Sent from my iPad using Tapatalk HD
How do you change input source level? You mean the level at which SR 6005 sends signals to PM7004
How would this amp run Dynaudio BM6 speakers? I am looking for an amp for them. Would the 6004 be good as well? It's price is more in line with my budget than the 7004
you can increase the source level for a particular input on receiver feom audio control amp menu option and input or incrwase rhe level of front left and right channel
