jaguarfree
I recently bought 50 inch Micromax TV (50B6000FHD), I downloaded few sample videos before downloading full movie. Problem is for 2 videos, audio was not detectable on the television. 1 video was of mkv format with dual audio, Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Hig....1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=3
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 21mn
Bit rate : 950 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.058
Stream size : 934 MiB (66%)
Title : Mafiaking
Default : Yes
Forced : No Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 2h 0mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 193 MiB (16%)
Title : Mafiaking
Language : Hindi
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 2h 0mn
Bit rate : 224 Kbps
can some1 throw light on this matter?? why this is happening and any solution???
Format : AVC
Duration : 2h 21mn
Bit rate : 950 Kbps
Height : 536 pixels
Color space : YUV
Bit depth : 8 bits
Title : Mafiaking
Default : Yes
Format : AC-3
Codec ID : A_AC3
Duration : 2h 0mn
Bit rate : 224 Kbps
Title : Mafiaking
Language : Hindi
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 2h 0mn
Bit rate : 224 Kbps
