Sounds like a game changer
Expensive and looks weird on the head, but the intro on Apple TV+ looks very impressive…
As you have experience with these, other than Apple which one would you recommend?The concept is not new. Meta Quest 2/3 VR headsets have most of the features. Apple is more refined and quite a bit more expensive.
I have the Rifts S and the Quest 2.
Meta Quest 3 is the latest version. Oculus Rift S is the earlier version, then the Quest 2 and now the Quest 3 and maybe soon, Quest 4.As you have experience with these, other than Apple which one would you recommend?
Do they come with a separate radio (Sim card connection)?
Thanks. Very helpful.Meta Quest 3 is the latest version. Oculus Rift S is the earlier version, then the Quest 2 and now the Quest 3 and maybe soon, Quest 4.
I would recommend the Meta Quest 3. Quest 2 does not have a sim card and I don't think the Quest 3 does either.
If one has a VR compatible computer, both the Quest 2 and the Quest 3 can be connected to it via the Air Link or via a connected cable. Steam games on the computer which can be played on the VR headset is a lot cheaper than the Oculus/ Meta games that can be played directly on the headset by downloading the same.
For streaming TV, the Meta Quest connects to your Wi-Fi network and uses the native streaming app like Netflix. Which means you will be consuming another device from your Netflix (or similar app) subscription. I haven’t tried casting a TV stream to the Meta Quest yet.Thanks. Very helpful.
So all of these are tethered to a computer of some kind?
I was hoping for a wearable device that can be used to watch Streaming TV without being connected with wires to another device/computer.
There was one like that on demo at the Bangalore what Hifi show some months ago. Can’t remember the details though.
