Kannan.Balasubramanian
Hi All,
Following are the equipments involved.
1. AV - Marantz SR 6010
2. TV - Sony 47-W850A
3. Dish Receiver - DishTV True HD+
4. PC - Custom Build with 7.1
Following are the connections
1. Dish [Out: HDMI] -> [In: HDMI 2] TV [Out: HDMI ARC] -> [In: Monitor(ARC)]AV
2. PC [Out: HDMI with PCM 7.1] -> [In: HDMI 4] TV [Out: HDMI ARC] -> [In: Monitor(ARC)]AV
In TV Bravia Sync is on with power controls
In AV HDMI Control is on with Audio as Auto (Other options are PCM and DTS)
In DishTV the audio in any channels (with 5.1 availability) is set as 5.1 instead of Stereo.
In PC I am playing 5.1 audio based content
For all the above cases, the AV shows the input audio as PCM 2.0 regardless of weather it's DishTV or PC.
But if I connect the DishTV or PC directly to AV then full multi channel audio is supported.
The issue seems to be with Sony TV converting audio to PCM 2.0 regardless of any type if input.
Has anyone faced same or similar issue ?
