Audio technica at-lp 120 usb power problem
Hussanalikw
Kuwait
Hello all..
I did again.. it seems it's a common problem here, so I pluged it in with 220V While it was on 115V .
I had read couple of Solutions here says to change the power glass fuse (220V 500mA) yes it was blown, all lights comes ON (working) but the motor didn't work. Some member here said that there is a secondary fuse under the center Circuit board (which I couldn't find or locait it).
Iam so tiered looking for circuit board map.
Is any one here have a solution for this problem? Please help!!
Hussain
Hello all..
Hussain
Does the motor receive DC?, If it does, did you run a check on the motor for short or open circuit?
