Audio Technica AT1240 LP USB TT
Amit Shetty
Does anyone have experience with this TT? I have been reading about it extensively and it seems that it rates very highly on review sites. Many compare it to the might Technics SL 1200 with some added features like USB, Built in pre amp etc.
Thanks in advance..
For DJing it is a good choice, no doubt because it's a direct drive tt and not belt driven. I'll always prefer a belt driven one because they are easy to fix. Also the motor noise can easily be avoided in belt driven tt.
My 2 cents is that the Project Debut III listed on your signature, would be a better TT. These ATs replicas are generally entry level and quite good if you keep your benchmark, low. They are definitely not in the league of the legendary SL1200 or SL1210 Turntables. If you are really keen on the SL1200, stay patient but alert, pre-used is the way to go.
Can't agree more. Advice straight from experience. The AT replicas are really nowhere close to the legendary 1200/10 TTs. As Reuben I am a direct drive fan as well.
Cheers...
Thanks for the responses. I'm in the US in a couple of days and following up on a 1200 MK2 actively. Hopefully will be able to close the deal. The technics was always the first choice but many out there are priced unreasonably.
Amit, with Technics DD (semi automatics or manuals) you cannot go wrong. The SL1200 is a 110volt model, the SL1210 has the 220volts option. If you are adventurous and have the money to spend, try the SP10, SP15 or SP25 decks (but you'll need a plinth and tonearm for these).
Are the1200MK2 110v only for the ones made in USA? Both me 1200s are 220volts.
I might know someone selling a 1200/II for non-extortionate, but not cheap, money. Comes with some Ortofon cart. Seller claims it is in good working condition. I have not seen it myself. Since it is used equipment, buyer beware, etc, applies. I can provide seller's name and number to anyone interested.
That's excellent. Like Reuben mentioned get a 220v model. If you have the budget and time and knowledge, an SP25 would be excellent. However please keep in mind these projects really require planning and proper execution.
If you do freeze on a 1200 ensure you pack this really well so no damage is done in transit. Whilst in the US get yourself a cartridge, record brush and other related stuff.
yes, the SL1200s from the United States are 110volt models, if buying in the United States, its better to go for the SL1210 as they come with the dual voltage option (110volts or 220 volts)
SP25s and SP15s available in the market are usually 110volts models while SP10s have external PSUs which are available with both voltage options, individually though, not switched
