Hi All,
Equipment : Denon 1713, Speakers : Wharfedale 70+.
Yesterday planned to recalibrate my speakers and took out the audyssey microphone. Plugged it in and it detected however when doing the test I am getting the error message "Speaker/Microphone not detected". When I try to twist or keep the MIC it works for sometime but again fails. Hence, audyssey MIC is not working.
Question:
1) Does anybody know where to get a replacement in Bangalore and the cost for the mic?
2) I have calibrated speakers manually(Distances,level,individual crossovers). Do I need to calibrate the 9 band EQ as well? Can I let it be default? Will it improve the SQ if I tweak the EQ?
3) I am a bit confused with speaker specs and I adjusted the crossovers manually can anybody confirm the right settings for the below specs:
Main/Surrounds:
Frequency range@ -6db : 120 - 20k
Xover Frequency: 3k
Frequency Fb: 110Hz
Center:
Frequency range@ -6db : 70 - 20k
Xover Frequency: 2k
Frequency Fb: 70Hz
Sub:
Boundary position: 28-170Hz
Xover Frequency: 70-170Hz
Settings in Denon:
LPF for LFE : 120 Hz
Individual crossovers:
Mains/Surround: 100 Hz
Center: 80Hz
Can I have some suggestions based on the above speaker specs?
Question:
Main/Surrounds:
Xover Frequency: 3k
Frequency Fb: 110Hz
Center:
Xover Frequency: 2k
Frequency Fb: 70Hz
Sub:
Settings in Denon:
Center: 80Hz
