AV receiver and speaker setup for TV
HellSlyne
Hi friends,
I'm planning to buy TV during this festive season. I'm looking for guidance to buy AV receiver and speakers to go along with the TV.
Need to buy:
1) AV Receiver, Soundbar/Woofer
OR
2) AV Receiver, Floorstanders and centre channel(if really needed)
Budget: 60k - 80k
Sources: DTH, PS4, PC
Usage:
Movies 40%
Games 10%
TV 30%
Music 10%
Room dimensions: 27ft x 13ft(not a regular rectangle. Narrower to the kitchen side and lot of furniture in the hall. Hence, the preference towards to less number of speakers)
Can I do without AV receiver? If I can, how many and which all ports should I consider for the TV?
Where can I audition the speakers in Bangalore/Chennai and where to buy?
Thanks in advance for any suggestion.
Sajit
Hi I think a HTIB will suit you better since your usage is mostly HT. Centre speaker is a must in any HT setup, but you need to plan for the surround speakers also. If you are not particular about a 5.1 setup buy the best possible AVR and towers for the time being. Later you can keep adding the speakers. I suggest not to go for sound bar. A simple 2 channel stereo will sound better
