Hi all the time has come to upgrade my HT setup. Well after issues with my existing AVR (Harman Kardon 260) (HDMI conked out), i had thought of upgrading the AVR but DD and DTS decoding being carried out I was putting it off. Well now that the AVR no longer turns on (it seems there is a problem in the standby circuit) I have finally decided to upgrade my equipment and so wand the esteemed advice of members regarding what my choices are and am I missing out on anything or what else should I consider.
My setup :
Placement in Living Room/Bedroom
Using Marting Logan LX 16 bookshelves Front speakers (am trying to get an matching centre)
A pair of Onkyo bookshelves as surrounds
A Sonodyne Roar 210 sub
The AVRs which I have shortlisted are as under :
1. Denon 4400h (9 channel, packed with features, but reliability ??, Audessy Room Correction)
2. Yamaha Aventage 870/880/1070 (7 channel, YAPO Room Correction, more reliable than Denon)
3. NAD 758 V3 (7 channel, Dirac LE room correction, 3 HDMI ins/1 out, Reliability ??)
4. Anthem MRX 520 (5 channels, ARC, Reliability ?)
One of the most important issues is going to be reliability and sound. As this system is exclusively for HT duties so mostly will not be used for music listening other than some casual listening. The movies are also limited to around 1/2 every week or less.
Please contribute all your views so I can make an informed decision.
My setup :
