elangoas
Hi All,
Below is a pic of my brothers living room, where he has 7.2.4 system in a 22(L) x 11 (W) x 10 (H) room dimension..
At present he has a 135 inch Vinyl screen, which has forced the center speaker to be placed much below ear level, not so ideal.. I had suggested him to build an AT screen for the entire width of the room and place the critical L-C-R speakers at ear level for maximum benefit, which he has agreed to..
At the same time i also thought of baffle wall to position the L-C-R and cover it up with AT screen, for additional benefit.. Similar to below picture..
There is also provision to mount surrounds and surrounds back to baffle wall (if that will also help)..
For surround left, there is a window to the left of the listening position, so we can flush mount the SL to the left wall..
For surround right, there is an opening to dinning area, which we have planned to erect a wooden wall with plywood.. So mounting surr right speakers & integrating it to the wall to create a baffle wall isn't a problem..
For surr back L/R too, a baffle wall behind the listening position is also possible..
There would be abt 15~18 inches of space if we remove the huge window behind the vinyl screen and erect an aluminium window to the outer side of the front wall and build an AT screen..
Is a baffle wall for all the 7 speakers a good idea?.. If it is a worthy solution to get away from the low freq issues for all the 7 speakers, then i would suggest him the same and plan on modifications..
Would be easier to integrate subwoofers on the frontwall too.. May be can go upto 6 subwoofers.. Subwoofers above & below L-C-R and ideally positioned to reduce width mode & height modes.. Length modes not so sure..
Appreciate your inputs..
