nithiraj.jio
Dear All,
I had a SONY Home Theatre (All-in-one) system. It was working fine for more than 12 years and now the amplifier is producing a high pitch hizzzing noise ( whistle ), which the service center said they cannot fix it as it is too old.
So, I am left with 5 speakers ( 100 watts rms each ) and a passive sub woofer lying idle, which I want to reuse.
I looked @ amazon for basic AV receivers like Denon AVR-X250BT 5.1 Ch, which fits my requirement exactly. But i found it needs active sub woofer. But I'm left with passive sub woofer, which i want to re-use.
Can you guys Please suggest some basic / entry level AV receivers which can support my existing speaker setup.
I'm a new member here. If this post does not belong here, kindly remove / move it to the right forum.
Thanks in Advance,
Regards!
Thanks in Advance,
Regards!
