best 40-42' TV under 40k ? is it VU 40k16 vs 42C0050UHD
sandys
hi guys,
I need a really good LED tv in the 40-42 size range. I live and die by my chromecast, so I have zero interest in a smart tv... but I will pay the premium if it means getting a better PQ or refresh rate or something. I also dont care about 4K but apparently those models have better PQ even for regular SD tv.
I'm talking best panel, picture quality, etc at the under 40k price range. Most of my watching is TV (of which most channels are SD) and then watching movies, etc on my chromecast... and using Hotstar or Netflix.
Try VU on flipkart. I'm not promoting or favouring the brand but its actually good. Quality is awesome. You can compare it with other brands before finalizing.
Yes I do agree VU is good but not sure about support. How about a non smart TV from Samsung, Sony.......
Sent from my Nexus 6 using Tapatalk
I dont think i see any at that price range. Can you suggest of any ?
If you are not allergic to Panasonic then there's a 43inch FHD smart tv on flipkart. Cost after discount is 39K. Looks legit.
