Stock? Where?
Sai123, I suggest you use proper punctuation, so that your posts are easier to read!
Did you check for the Panasonic 42X30 plasma? Is it in stock. That would be within your budget.
In this budget a plasma tv will, in most cases, have better picture quality than LED or LCD TVs. But if availability is a problem, try something like the Samsung 40EH5000.
no led is less than 40k....40k is toshiba lcd i think....for 40 incher.
you buy samsung 470 plasma 43 incher at your budget....very good tv.
its aropund 37k......
or pana 42 inchers plasmas are also good
demo them first....then proceed
Ya,first i booked 43e470.But he said that it is not available in stock.E400 and E490 are in stock.I couldnt take either of them because the former has very low resolution and latter is around 49k.and Of course i asked him about Panasonic plasma but he said that only 3d model of 50k is available. so what to do!!!!!!!!!!!!!!!!!!
check out the lg 42LK450, its a 42inch set available at 37-38k.
