Gaurav55
I want to purchase new av receiver but I am confused between yamaha pioneer and denon
There various brands AVR available here in our country like Anthem,Arcam,Marantz,Denon,Yamaha,Onkyo,Pioneer etc.,I want to purchase new av receiver but I am confused between yamaha pioneer and denon
it's a big size room. you would need powerful AVR & speakers. you can consider Yamaha RXV685, Denon X2500H or pioneer VSX 934. I don't know much about Onkyo. You can hook it up with a pair of floorstanders and a centre channel speakers and can add sub & surrounds in future to build your system step by step as 1L will not be sufficient for a such a big room to have complete 7.2 ch system.Budget 1L with speaker and room size is 20*20
Which one is best Denon AVR-X2600H or Marantz NR1609 or Pioneer VSX-LX304 or Onkyo TX-NR696it's a big size room. you would need powerful AVR & speakers. you can consider Yamaha RXV685, Denon X2500H or pioneer VSX 934. I don't know much about Onkyo. You can hook it up with a pair of floorstanders and a centre channel speakers and can add sub & surrounds in future to build your system step by step as 1L will not be sufficient for a such a big room to have complete 7.2 ch system.
You could add marantz also. Yamaha, denon or Marantz all are good. Depending on you budget and room size and features you need to decide. Best is to visit the showrooms and take demos to get a fair idea of avr, speakers etc
Which one is best Denon AVR-X2600H or Marantz NR1609 or pioneer VSX-LX304 orYou could add marantz also. Yamaha, denon or Marantz all are good. Depending on you budget and room size and features you need to decide. Best is to visit the showrooms and take demos to get a fair idea of avr, speakers etc
Which one is best Denon AVR-X2600H or Marantz NR1609 or Pioneer VSX-LX304 orThere various brands AVR available here in our country like Anthem,Arcam,Marantz,Denon,Yamaha,Onkyo,Pioneer etc.,
U may need to tell your tentative budget ,your room size and the speaker layout you are planing,so that FMs can suggest right options...
Denon 2600h is the latest and good one for your room size.Which one is best Denon AVR-X2600H or Marantz NR1609 or Pioneer VSX-LX304 or
Onkyo TX-NR696
I want av receiver for both for movie and musicIf your usage is mostly movies, go with the Denon. If budget permits consider higher model, 3600 or 4600.
Thanks for reply please tell me which speaker is best for itDenon 2600h is the latest and good one for your room size.
Thanks for reply I want av receiver for both for movie and music
any other speakersGet denon 2600 or 3500/3600. It's the best for movies also good for music. For speakers, you can go for pioneer Andrew Jones fs52 and center channel. Best speakers in that price range. You can check out the reviews of the same. Won't be disappointed.
