prateekatasniya
Don't want a stereo speaker. Need a single Bluetooth speaker.
Suggest the best.
Good bass is must.
Suggest the best.
Good bass is must.
Suggest the best.
Good bass is must.
Should have a battery.If I may ask what will be the source? Some streaming service on phone? And what is the stage of performance like bedroom listening, portability,, TV amplification((soundbar) ? What I want to understand is if 40k is budget which I haven't seen anyone recently spending on bluetooth then for future proofing I will suggest get a good Bluetooth DAC and a separate active speaker. If portability is must then aspects like battery backup, size will come into consideration. If multi-room future connectivity or Features like Alexa control is a consideration then these are going to change which you need to call out. Note that if you don't needs met proofing and it's only for partying then get a Bluetooth enabled biggies from companies like JBL or Sony who even make DK units for that budget. Also check below link
https://www.whathifi.com/best-buys/hi-fi/best-bluetooth-speakers
Indian price ?DynaAudio Music 1 or 3.
I listened to them in a hifi shop... Just wow sounding device. Looks good too.
Have you checked the Bose lineup? SoundLink Revolve+ Bluetooth® speaker in particular.Don't want a stereo speaker. Need a single Bluetooth speaker.
Suggest the best.
Good bass is must.
I don't like to buy something without knowing the specs.
Way out of budget.Recently got to listen to B&O A6 bt speaker. One of the most refined sq with decent bass. A bit expensive but very good.pl Google for more info
And I don't trust this brand.
